Hi all--we need to replace our house battery that is housed underneath the seat in the back. Is there a trick to replacing it without removing the pivoting bench? Doesn't appear to be a way but wanted to make sure first. Searches are coming up empty. Thank you!
I've removed the back rest bolster, slid the bed all the way out.Legs down! and accessed the battery that way. My back rest is only held by turn buttons on straps.
How do you get to the battery on the EB50 when you want to replace it?
Pretty easy to remove the back bench seat bottom. Lift it up part way and you'll see 2 nuts on each side (4 total) toward the back holding the seat to the folding frame. Remove them and the seat bottom will lift out. At least that's how mine is.
Joe
2003 EB50 7.3L PSD Q4X4
2003 EB30 - Sold
But then my house batteries are mounted outside under the side doors and forward of the spare tire so maybe seat removal info is not what you need.
Joe
2003 EB30 - Sold
