Tilt out window shopping list
Based on my experience here is the list of parts to get from the donor van. Get all of them the first time you are at the recycle yard. The parts you forget may not be there when you go go back for them. Don’t ask how I know.
1. Window latch and three screws. The latch mechanism unscrews from the bolt that goes through the window. Leave the bolt assembly attached to the window.
2. Window trim. Be assertive when pulling away from the retaining clips. The color of the trim does not matter. You can always spray paint it.
3. All metal clips and associated nuts that hold the window trim in place. Leave the hinges attached to the window.
4. The window.
5. The window frame that seals to the opening in the door. This is probably the most difficult item to remove. The butyl caulk makes for a tight and sticky seal to the door. Suggest wearing rubber gloves to keep the butyl off you hands and fingers.
6. The screw plate that the latch screws into.
7. Bottom door trim panels if you want matching upper and lowers.
Larrie
