Old 12-01-2019, 05:13 PM   #1
Insulation Ford e-250
Another help question. What is the best option for insulating foam or Thinsulate? Most R-value and most noise reduction?
Thank you,
Joe Futrmobl
Futrmbl is offline   Reply With Quote
Old 12-01-2019, 05:42 PM   #2
marret's Avatar
I would suggest Thinsulate over foam.
Chris
Old 12-01-2019, 06:14 PM   #3
Ok thank you very much>
Futrmobl
Old 12-01-2019, 08:11 PM   #4
MSD
MSD's Avatar
Your not gonna get much sound deadening from thinsulate, multiple layers of thermozite will give you both or any type of Dynomate or knock off like be quite or kill mate & thinsulate can achieve what your looking for...
2003 Land Rover Disco II
1997 E350 7.3l 2wd - Sold
Old 12-02-2019, 05:24 AM   #5
marret's Avatar
MSD provides excellent recommendations. For sound deadening, Dynamat works well (believe this may be what MSD means with Dynomate?).
Chris
Old 12-02-2019, 09:25 AM   #6
MSD
MSD's Avatar
Yup that is correct dynomate not dynamat I’d actually never pay what they want for there product since there are great alternatives @ a lot less $$$.
Old 12-02-2019, 09:35 AM   #7
Hello MSD.
GreaT Alternatives?
Thank you,
Joe Futrmobl
Old 12-06-2019, 08:14 AM   #8
REF
REF's Avatar
Send a message via MSN to REF
Yes, I covered the entire van interior walls with Noico and used thinsulate with the black scrim backing for insulation. Expensive, but probably the one if the best products out there for our applications-doesn’t hold moisture, isn’t toxic, won’t break down or get compacted and won’t warp the wall skin like spray in foam.
3M Thinsulate Acoustic/Thermal Insulation SM600L (50' x 60") https://www.amazon.com/dp/B074XLDV58..._nTM6Db39TKQZ8
Super nice to work with, easy to cut and install with a little spray adhesive. I will point out, Thinsulate does provide a fair bit of acoustic insulation as well as thermal. It will not address any sheet metal resonance or the hollow door sounds though, that’s what the Noico (or dynamat) is for, but it does provide a “blanketing” effect.
Old 12-06-2019, 09:29 AM   #9
Thank you very much for your time and information. Helped me coming up with the solution.
Joe, Furtmobl
My van has a Quigley system, RB 250 building it my self.
Finish contractor carpenter 40 years
Old 01-30-2020, 05:05 PM   #10
Hey REF or anyone who has done this—how much Noico do I need? I have a pass van and plan to do the walls under and around the windows. Eventually want a pop top so I won’t be doing the roof. Haven’t had a chance to jump in there and measure yet. I figure someone with experience might have a better with how much is actually needed to get in all the books and crannies. Thanks!
thejm is offline   Reply With Quote
