Well this may be turning into more of a project than I expected.
I contacted CCV and they use
Dicore Lap Sealant to caulk the bolts. Can one of you that has a CCV top look at your roof bolts and see if the caulk is covering the bolts or not?
The bolts on the CCV top are not as easy to remove and re caulk as the ones on the SMB top as the nuts are inside the metal channel frame that supports the roof. In addition the center nut is blocked by the screw jack that raises the roof. It looks like I will need to block the roof up with braces in order to remove the screw jack so I can get to the center nut.
While I was inspecting the bolt locations on the inside I noticed that one of the nuts at the end of the screw jacks had come loose. I was going to tighten it when I noticed that there appears to be a black plastic sleeve around the bolt. Can anyone familiar with CCV tops verify this?
