Thanks everyone for the kind words, it was one of those projects that took me way too long to complete. But I did also re-wire a lot of the accessories and re-did the factory headliner.
Originally Posted by SteelheadJones
That looks factory. Have you considered selling templates?
There are so many variables that I'm not sure it would be beneficial for / to anyone. All the angles / curves are very dependent on how high and at what angle you mount the console, along with the depth from windshield you are after. I wanted as shallow as possible but to perfectly fit the sun visors, and my height was dictated by the switches & gauges I wanted to mount. Plus I'm running stock headliner with insulation behind it. So probably very different to others. IE SMB has no factory headliner, and most with factory headliner don't have insulation behind it.
For a template to work, you'd also have to use / manufacturer identical mounting brackets and be very precise on where they are mounted.
If I pull it down for any reason, I'll certainly draw it up in CAD for anyone who wants to use it for a base line.
