Hey all, new SMB owner 2006 v10 E350 4x4, electric penthouse. Everything works, lower miles, mechanically sound, and no rust issues. Lights and some other aspects of the interior are dated and need some changes but I figured I would enjoy it as is and make changes as I go. We took it out for a close by one night trip that went well and a TV became my wife's main ask. I started researching and combing through the forum and have found some interesting stuff that I should have known had I done more research on these before buying, but that's my tendency when it comes to new toys / projects.
As I mentioned everything works. Top goes up and down and everything to my untrained eye seemed ok. The only place I could see setting up a tv was from the penthouse roof towards the driver/passenger seats with the ability to fold it up out of the way when not in use. This led me to posts about the penthouse tops, leaks, springs, bolts, etc. Opened up the top and yeah, I could see the canvas being tighter / higher, and oh yeah, the support tubes don't look straight, and oh yeah they aren't, and hey looks like the light up there isn't working because of the bulbs, looks like the wires are cut and that was going to be my source for the TV, etc.
I've found a lot of good info and post about specific items but I'm talking about doing them all in one swoop. I want to straighten and reinforce the tubes, upgrade the bolts, reconnect the power, replace existing light with LED, and basically do whatever makes sense "while I'm there".
Here are my steps/questions as I see if based on the posts I've read...
- Raise the top
- Straighten bars
--Is this best done in place before supporting roof or should I remove and straighten?
- Support the top
--How high do I try to get it? One post mentioned that the cross bars along the top should free (not touching top or block support). Is that good enough?
--I want to remove the headliner in order to create a support point for a TV mount so what comes first, supporting the roof or removing the headliner
--Sounds like removing the headliner disconnects the canvas is that correct?
- Release spring tension
--My chain has two links, is this too short for the come along process
--I want to straighten and re-inforce all tubes so what is the process things to look for in order to fully remove the tubes. Obviously all the bolts need to be removed but wondering what the best sequence should be
- Remove headliner for mounting and electrical
--Canvas will fall down? Add furring strips but is there a trick to getting the canvas back up correctly?
- Straighten tubes
--assume out of the van similar process with the high jack can be applied? Then add CroMo inserts
- Deal with wiring and LEDs
- Reinstall headliner / LEDs
- Reinstall support tubes, new bolts, and roof blocks
Any advice / posts / ideas on how to handle the headliner under the penthouse? Mine appears to left over from the original headliner with seat belt hooks, indentenations, etc and the lights that go around it need replacing. Any cool installs that cover this up without the factory pieces would be appreicated or ways in which the factory pieces have been modified to delete the hooks and indentations.
Thanks.
