If you are careful getting the pins out you can reuse. I have done 4 or 5 tops now and never had to buy any.
Having the top off the van and down lower (I use sawhorses) makes spraying consistently over the top pretty easy. I've been able to get it uniform. Sportsmobile tops are actually pretty easy to remove. A second person is only needed to actually walk the top off the van which we have done through the rear door.
I'm still curious which rollers are best for rolling Raptor Liner. Monstaliner sells rollers which supposedly give you the proper texture but I'm wondering if one of the many types of rollers from a local paint store (or Lowe's, HD, etc.) would work as well.
Brian, please post that roller link.
Railvan, which roller did you use that did
not give you the texture you wanted?
Thanks
