I know a lot of people use a ScanGauge but i haven't seen much about where they mounted it. I love that little gauge and this is where i mounted mine.
It was very easy. It helps that my seats flip up and slide way back! First you'll need to remove your doghouse.
Then remove this bracket to give easy access to the back of your dash. Only one screw
And this is the view you get without the bracket (looking straight up behind the lighter plugs).
One little hole here, route your wire through...
Some electric tape to cover the side plug-in.
Double-sided tape and that's it, easy pie!
Cheers
David
Sent from my SM-G900W8 using Tapatalk
