Old 03-07-2016, 10:45 PM   #1
Abitibi's Avatar
ScanGauge mounting point
I know a lot of people use a ScanGauge but i haven't seen much about where they mounted it. I love that little gauge and this is where i mounted mine.
It was very easy. It helps that my seats flip up and slide way back! First you'll need to remove your doghouse.
Then remove this bracket to give easy access to the back of your dash. Only one screw
And this is the view you get without the bracket (looking straight up behind the lighter plugs).
One little hole here, route your wire through...
Some electric tape to cover the side plug-in.
Double-sided tape and that's it, easy pie!
Cheers
David
Sent from my SM-G900W8 using Tapatalk
2008 E350 Hambo
2001 E350 AmbuLand (sold)
1970 Econoline popup camper
1965 Econoline Travelwagon
A few bicycles...and sandals ;)
Abitibi is offline   Reply With Quote
Old 03-10-2016, 03:03 PM   #2
Nice work, I placed mine in the exact same spot a couple years ago. For some reason I do not remember even having to remove anything, just drilling the hole and reaching up behind the dash.
Old 03-10-2016, 05:30 PM   #3
I did the same. Just fished the wire up from under the dash. I think I remember using an old wire hanger to grab it from the top side as well.
1998 E350 4x4 7.3l Club Wagon Chateau with SMB top
trquinn is offline   Reply With Quote
Old 03-10-2016, 11:50 PM   #4
Bellpilot's Avatar
That is exactly where I installed mine!!
2010 E350 6.0 4x4 EB 50 SMB
Bellpilot is offline   Reply With Quote
Old 03-11-2016, 12:01 AM   #5
Abitibi's Avatar
I just found it way easier to remove the one screw and move that bracket out of the way but good to know it can be done without. It was just easier for me to make sure there was nothing else in the back that I could have risked drilling through!
To be honest I can't figure a better place for it!
Cheers
David
Sent from my SGP511 using Tapatalk
2008 E350 Hambo
Old 03-11-2016, 01:10 AM   #6
SixCardCharlie's Avatar
Great spot. I have mine temporarily velcroed on the dog house. Before that it was just all over the place. Im waiting to incorporate it to my overhead console when i build it.
2004 6.0 PSD
SixCardCharlie is offline   Reply With Quote
Old 03-11-2016, 08:54 PM   #7
Oogs's Avatar
Nice install. I used a Blend Mount to put mine above the rear view mirror. The kit comes with and extension cable.
Oogs is offline   Reply With Quote
Old 03-11-2016, 09:37 PM   #8
Abitibi's Avatar
You guys with different mounting options should post a picture here so people looking to mount theirs could get a better idea
2008 E350 Hambo
Old 03-18-2016, 11:34 PM   #9
JoeyNick's Avatar
Good spot. That's where I put mine back in 2009. Writeup:
http://www.sportsmobileforum.com/for...tlet-2236.html
2005 Ford E-350 Diesel Sportsmobile
EB 102 Voyager top, 3.55 rear, Mobil 1 all around
270 amp alternator, billet water pump, coolant filter kit,
aluminum radiator, X-Monitor with pyro, trans temp, boost
+ Scan Gauge & SCT Live Wire (Economy)
JoeyNick is offline   Reply With Quote
Old 03-18-2016, 11:50 PM   #10
Abitibi's Avatar
Looks like it's the logical position for it if so many of us end up with the same idea
I will look into the 12v passenger outlet though, thanks for sharing!
David
2008 E350 Hambo
Turtle
rafeman
Betsy
Dave&Di
