Old 03-31-2024, 11:45 AM   #1
Seam Sealer Recommendation for CCV Poptop
Lovely wife and I were out this weekend, Friday night we had an all-night soaker - probably an inch over 8 hours. Perfect time to find any leaks.
Seems like we have a bit of water intrusion coming in under the windows where the seams clear and screens are sewn to the main body. Everything appeared dry above that plane.
Makes sense, you can see pinholes in the tent fabric where the screens and clears are sewn in.
What do you guys recommend for sealer? I have looked at two options -
Seam Grip WP which is not water based, takes a long time to dry, but should be bomber.
Seam Grip FC water based, fast cure.
I am concerned the "FC" is not a gap filling material, and I need to fill some gaps, the pinholes are sizeable.
Any recommendations are welcome.
Big_ern_101 is offline   Reply With Quote
Old 03-31-2024, 11:56 AM   #2
Just as a suggestion - what about a bees wax/stick product - inexpensive and wax should be flexible and just a rub on/roll on product - easily replenishable - I've used it on my 2002 PH top - Amazon of course - rub it on inside and outside of seams -
Let me know it works for you -
Old 03-31-2024, 06:24 PM   #3
1der's Avatar
303 Products Fabric Guard spray
or,
Iosso Seam Seal
Like doublevan2 recommends - inside and out
Old 04-01-2024, 07:35 AM   #4
Thanks for the recommendation - gonna go after it with fabric guard and iosso seam seal
303 products have never done me wrong.
Old 04-06-2024, 09:47 AM   #5
Thanks again - hosed it all down this weekend.
Will see how it does. I did my red EZ-Up as well, really brought it back to nice and bright.
Old 04-07-2024, 10:13 AM   #6
We use Iosso Seam Sealer and 303 Fabric Guard every three years or so; both seem to work well.
Jim
jim2901 is offline   Reply With Quote
