Sprung a leak last weekend at Palo Duro Canyon. Has anyone repaired the Attwood rear shower? I got the leak stopped but the shower leaks thru the head (like the seat washers need replacing). Hoping they are replaceable like delta or some such.
Thanks, Brent
The issue was buildup from the h/w tank and/or hard water that prevented the mechanism from closing all the way. It's possibly disassembly and cleaning will solve your leak.
Thanks Jage. I'll clean the workings good. I get some water thru both the hot & cold on/off valve. I turn on the water pump and water drips out the shower head. Sounds like I need the clean the shower head as you did but also the hot/cold on/off valves.
Thanks, Brent
