Old 03-25-2010, 08:27 AM   #1
shower leak
Sprung a leak last weekend at Palo Duro Canyon. Has anyone repaired the Attwood rear shower? I got the leak stopped but the shower leaks thru the head (like the seat washers need replacing). Hoping they are replaceable like delta or some such.
Thanks, Brent
b & j
b and j is offline   Reply With Quote
Old 03-25-2010, 10:31 AM   #2
Re: shower leak
I don't think this is the Attwood, but I don't know what SMB uses:
viewtopic.php?p=24052#p24052
The issue was buildup from the h/w tank and/or hard water that prevented the mechanism from closing all the way. It's possibly disassembly and cleaning will solve your leak.
Old 03-25-2010, 11:39 AM   #3
Re: shower leak
Thanks Jage. I'll clean the workings good. I get some water thru both the hot & cold on/off valve. I turn on the water pump and water drips out the shower head. Sounds like I need the clean the shower head as you did but also the hot/cold on/off valves.
Thanks, Brent
b & j
