Old 06-22-2020, 07:29 PM   #1
Angry Sprinter SMB alternator failure
I have a 2016 SMB Sprinter buildout with a Nations secondary alternator charging the house batteries in addition to a couple of solar panels. In 40k miles, I've had three of these alternators fail due to a corroded power stud. In my experience this seems like a far to common issue. If anyone else is seeing this as well, please chime in, particularly if you have found a solution.
BTW I'm in Montana where we don't salt our roads.
daytripper is offline   Reply With Quote
Old 06-23-2020, 08:09 PM   #2
Flyview's Avatar
What is the power stud that's corroding part of? The second alternator?
I would try a different brand if a few have failed this way.
Full time vanlifer in my SMB.
@man.and.van on Instagram.
Flyview is offline   Reply With Quote
Old 06-27-2020, 07:57 PM   #3
Have you tried coating it with dielectric grease. I believe the second alternator is mounted pretty low correct? Does your second alternator have an external regulator, are your house batteries lithium?
Tags
sprinter alternator
Ford Zilla
Steve C
VanBo
Mike Ponce
