At the suggestion of Daveb I am posting this information in a little more detail for those of you that are looking for a true plug and play good LED Porch Light Replacement , made by
http://www.starlightsinc.com . The beauty of this light is that you remove existing Bargman Porch light that comes with your SportsMobile and using the same screw holes that are predrilled in your Van and replace with the Starlight . They provide the screws and needed Butt connectors in the kit and make the change out a very simple affair , about 20 minutes . This light is not only adjustable for sensitivity but will give a means of monitoring a low a low battery condition via its indicator lights that are easily seen while outside your vehicle . Blue is daytime , Green is at night and Red would indicate that your battery is at 11.5 volts at which point the light does not function and you can make provision's for recharging your battery . Be sure to specify LED
when ordering or you will get the energy robbing incandescent like the one provided with your stock light . As near as I can tell this relative bright light only draws 1/10 of an Amp per hour and the motion sensor is really amazing for those of you wishing for security and the light is available in Black or White . I finally posted a couple photos in my Gallery of the installation .
In fact SportsMobile is now offering this light as an option , be sure to specify the LED Bulb
Greggde
PS You can operate this light as a normal Porch Light as well by simply turning the existing switch inside your Van on and off like your stock light .
