Originally Posted by N147JK
For a long time I thought that was the case as well - that a battery that is compromised internally would interrupt even a jump start.
I'm not suggesting it will 'interrupt' a jump start. If the starter load is low enough that the jumper cables can carry the current, no problem.
Usually (if it hasn't been sitting months/years) the starting battery still has something left in it, and jumping it gets it over the 'hump' to actually crank the engine fast enough to start.
Sometimes, if the battery is dead enough or the load is high enough (diesel engine) the 50A the starting battery can contribute in it's depleted state plus the 50-100 amps jumper cables can contribute just isn't enough to get things moving.
Maybe I encounter this more often than normal because I have so many large vehicles, or because I retrieve alot of dead vehicles. Maybe all 4 of my jumper cables just suck. My experience after owning/fixing/flipping over 100 vehicles is that a fresh battery is always better than jumper cables.
Think of the contact area on jumpers compared to suggested wire gauge... it's inadequate.
