Old 11-22-2021, 09:51 AM   #1
pjpvi's Avatar
Sway bar holder
Figured I would share this little project that I've been thinking of doing for the last 15 years.
When running with my sway bar disconnected I've always secured it with a bungee cord. I've used the same bungee for the last 15 years and it stopped having "bungee action" many years ago and is basically a cheap piece of rope with two hooks now. It works, but not an elegant solution at all and I have always wanted to make a bracket that I could use to attach the sway bar link to to hold the sway bar up and out of the way when it is disconnected.
So, here is the result of the project in pics. I just finished about 3 weeks in Baja and it held just fine after many many harsh off-road miles (sorry, kilometers!).
bungee and bracket.jpg   bracket 1.jpg   bracket 2.jpg   bungee sway bar holder and new bracket.jpg   sway bar holder 2.jpg
Phil
- 2005 EB50 6.0PSD - SMB 4x4
Old 11-22-2021, 10:29 AM   #2
shenrie's Avatar
That’s slick. Nice execution man!
Old 11-22-2021, 10:51 AM   #3
Yes very well done.
Old 11-23-2021, 10:44 AM   #4
BVerhulst's Avatar
Excellent idea and design - I'd been thinking of something similar for quite a long while. I'll definitely be referencing this as I work on my own. Keep us updated if it continues to work well. Did you place one on both passenger and driver sides of the vehicle?
Brian
2009 E-350 Lopes 55
BVerhulst is offline   Reply With Quote
Old 11-23-2021, 12:00 PM   #5
pjpvi's Avatar
Only on the driver's side. I've only ever used the bungee on that side and since it is only holding the rotational weight of the sway bar, 1 side should be enough.
After the Baja trip I'm confident it will hold for the long haul. I managed to snap my driverside spring / shock / track bar bracket through the u-bolt holes as others have done and snapped the bolt on the rear strap holding my Transferflow fuel tank this trip. If those failed and this held I feel good about it. Of course my next project is to spend time on the front end working on shock compression / extension limits, bump stops, brackets and maybe limit straps. The bump stop mods I did on the rear axle have made a world of difference and I need to replicate that up front. That will be a story for another post though ....
Thanks everyone for the positive comments! I appreciate them.
Phil
