Working down to the lower section installed the same LED tracks as in the penthouse and removed all the old school lights. Installed a dimmer at the barn doors in the side trim. I'll be attempting to fix the holes in the side trim with Christmas tree plugs as well as velour fixes if necessary. I decided to pull out the driver side cabinets so I can get some solid screws installed to keep the rear trim up. I had a local shop redo all the upholstery and things fit a lot tighter than they did before. The re-installation so far has been to install the top penthouse piece, followed by the underside piece with the box on the passenger side that fits over the electric motor. I started by lining up the top and lower pieces so the rear roof latch bolt could be connected and then used a rubber mallet to get everything lined up. The rear piece that connects to the two L brackets on the back went in next. Screwing the lower piece into solid points is next. I added two 12volt socket in the upper rear penthouse piece and will show pics when the rain slows down and I can get the top up.
