12-23-2011, 09:01 AM
#21
Re: Upgrade from Ford Factory Stereo; Speaker Location?
Depends on how many speakers you have, 4 or 6. Try http://www.crutchfield.com. They have a better lookup tool. Mine - 2006, white one, 6 speakers.
Callsign KK6GIY
12-23-2011, 09:05 AM
#22
Where would they be?
I have two up front, one in barn door, and either one or two in rear doors.
Sounds like 5/6?
On Crutchfield for both 4 and 6 speaker 2002, it showed me the same one, black.
It looks to me look the rear speakers are all connected together, so the plugs on my year are the same.
(edit) I figured it out. One plugs into vehicle harness, other one is different sex for plugging into radio.
This one plugs into harness, and is cheaper:
http://www.amazon.com/gp/product/B0002B ... PDKIKX0DER
Sportsmobile-less.
12-30-2011, 01:22 AM
#23
Anzac - This is the double din dash kit I used. One warning, I don't think you can remove the stereo without removing the dash once it is installed. The side mounts have one-way clips that secure the stereo to the dash. There is a warning that comes with the instructions that is conveniently left out of the product description on Amazon...
http://www.amazon.com/gp/product/B0009JSDYC
So, instead of the double din metal sleeve and big Kenwood escutcheon, I use the black one way clips secured to the radio side, and the escutcheon from the kit? And I still have to Dremel out the dash opening?
What is the triangular piece of black plastic for?
My head unit is a Kenwood dnx6980.
Sportsmobile-less.
12-30-2011, 11:51 AM
#24
Yes, the radio will not fit unless you widen the opening. It's not quite double din standard size, close but no cigar.
The triangular piece attaches to the back of the radio. There is a metal railing on the bottom of the radio opening that it slides on to. It's optional in my opinion but it provides a more secure mount. The DNX7140 does not have a threaded nut to attach it but there is a hole that you can use a wood screw or similiar.
Callsign KK6GIY
12-30-2011, 12:22 PM
#25
Thanks. Now I can't get the OEM head unit out. I have the correct tools.
Is it fastened at the rear? Is removing the doghouse best way to get rear access?
Sportsmobile-less.
12-30-2011, 12:55 PM
#26
Pull harder! Removing the dog house will give you considerable access.
Callsign KK6GIY
12-30-2011, 02:23 PM
#27
I pulled harder but the tools pop out at a certain point.
Might take out doghouse and see if I can push from the back.
Sportsmobile-less.
12-30-2011, 06:10 PM
#28
I got it out, I needed to push out sideways on the tools. (duh)
The rear support won't fit on the 6980, even if I could mount it, it would obstruct the cooling fan.
Sportsmobile-less.
12-30-2011, 07:47 PM
#29
A long zip tie around the stereo/bottom bracket would be a good substitute.
Callsign KK6GIY
12-30-2011, 09:19 PM
#30
Originally Posted by Yubariver
tweeters within the black plastic deltas that sit in the front window corner of the door. The tweeters sit at almost ear-level, and swivel towards the driver’s/passenger’s ears, and as such, the sound is fantastic, and it cuts through the diesel noise better. This was a pain in the butt to run the wires, cut the tweeter holes, etc, but I think well worth it.
Tweeters, yes. That's what the stock Ford audio setup seems to lack -- the high range.
Any idea whether I could do this with the stock Ford radio? Is there a way to wire tweeters up in parallel with the front speakers, or do I need a head unit with extra channels?
I'd love to keep the Ford head unit for its theft-repellant looks
-- Geoff
