How bad was swapping the orifice? Seems like a disassembly is in order. Swapped in the new fan super quick, just not sure on this next part...
OK, finished this without a ton of trouble. It was a a 1 out of four banana job. Will be firing it up soon to see how it goes, but if you're on the fence, it's maybe a 2 hour job!
Sorry don't check this often. The most work is getting the heater out. Once that is done it's easy to take out the burner orifice. Be careful with the gaskets as they are very fragile and they are probably asbestos.
How does the upgrade work for you? I'll be trying mine out in 14 degree weather this week.
