Old 09-29-2022, 12:10 PM   #1
pcdarks's Avatar
Upgrading your old Suburban heater
Those of you that still have a vintage Sportsmobile van Circa 1990s-2000 with the penthouse. I have a 1995 Dodge B3500 with a suburban NT12-Se propane heater. I go many cold places and researched getting a larger hear to help. what I found was a new heater was $500+ My research showed that There is virtually no difference between the NT12 and the larger NT20SE. The 12 is 12,000BTUs and the 20 is 19,000btus. All of the parts are interchangeable except for the orifice which is larger for the bigger heater. $7 for the orifice here, https://pdxrvwholesale.com/products/...orifice-180231.
While I was at it I changed the fan from the SE series to the SEQ which is a more modern design and runs quieter here. https://pdxrvwholesale.com/products/...mpeller-350207.
As a result I was able to do the upgrade for less than $30 and My heater puts out much more heat and runs for shorter times because of the upgrade. It is also quieter. Both parts install easily for the average do it yourself-er and are a direct fit on the motor and burner.
pcdarks is offline   Reply With Quote
Old 09-29-2022, 12:30 PM   #2
This is interesting. I have an old NT-12 and the fan is very noisy. The website doesn't list the model 12 as applicable for the upgraded fan. But you installed it in a 12 "chassis" and it fits and works?
Old 09-29-2022, 01:02 PM   #3
pcdarks's Avatar
Yes, It still makes noise but much less early serial # too 0227X
Old 10-06-2022, 10:16 AM   #4
Was the upgrade worth it?
bisonthecruiser is offline   Reply With Quote
Old 10-07-2022, 07:46 PM   #5
pcdarks's Avatar
I went on an overnight-er to test it. It ran strong,heated much quicker and ran quieter. It's also pretty easy to pull the heater out,dismantle it to replace the fan and orifice. The only thing to watch for is damaging the gaskets. I was able to reuse mine. $30 you be the judge.
Old 10-07-2022, 08:32 PM   #6
Sorry, somehow missed your review in the original thread. Yeah, certainly looks worthwhile.
Old 10-07-2022, 11:29 PM   #7
Thanks for sharing this excellent info with links !
Stone Cite is offline   Reply With Quote
Old 10-15-2022, 05:02 PM   #8
pcdarks's Avatar
I took it out for a trial run. 28 degrees it worked perfect heats faster and the sound of the fan actually lulled me to sleep.
Old 10-27-2022, 12:43 PM   #9
pcdarks's Avatar
https://www.sportsmobileforum.com/fo...ade-30811.html
Old 11-26-2022, 05:25 PM   #10
How bad was swapping the orifice? Seems like a disassembly is in order. Swapped in the new fan super quick, just not sure on this next part...
Vantastic
maxx
Hermes
Nimzero
