Old 09-20-2021, 11:27 AM   #41
Glenn P.'s Avatar
I've had diesel in a pair or those Rotopax 4 gallon containers mounted up under there since Feb and I have not vented it once. Been from near freezing to over 100 degrees and no leaks or any issues.
And in regards to the "structural integrity" issue of removing the tire winch, You need to look for your yourself. On my 2005, it is just that, a simple little tire winch with 2 bolts holding it in place. It provides ZERO structural enhancement to the van. Perhaps other years are different or maybe you are talking about cutting out more stuff under there but I made the Rotopax mount possible by simply removing the spare tire winch and drilling a few holes to the existing bracketry that is under there.
Glenn P.
2005 Quigley E350
6.0L Diesel
Glenn P. is offline   Reply With Quote
Old 09-21-2021, 08:25 PM   #42
Yeah I was talking about removing the entire mounting structure in addition to the tire winch.
- Hustle can beat talent, but when talent hustles, your're screwed
'06 E350 6.0 PSD EB-50 4x4
'04 KTM 525 EXC. '12 SkiDoo Summit ETEC 800
'76 Ford Hi-Boy, '72 Baja Bug, '83 CJ 7
GunniLuv is offline   Reply With Quote
Old 09-22-2021, 11:23 AM   #43
Flux's Avatar
On my EB, there is a very substantial cross brace in front of where the tire mount was.
I will echo the sentiment that you should have a rear hitch in place if you remove the tire carrier.
<br>
Old 09-22-2021, 01:15 PM   #44
1der's Avatar
If not already linked:
Post #8 covers everything about removing the OEM spare tire X-brace. The frame cross member forward of the spare tire space should not be removed.
Absolutely one of the top five posts - #8 - EVER!
https://www.sportsmobileforum.com/fo...bly-22906.html
