Old 02-26-2020, 01:34 AM   #2931
Kibo's Avatar
Made a minor tweak to the Webasto AirTop 2000 STC installation.
Those of you with a MultiControl HD may know that there's a temp sensor on the controller (which strangely isn't used by the AirTop to control the temperature). If you read the manual, one can enable the Show Temperature feature from the Service menu to display the temp senor value in the status bar...but you need the diagnostic interface to do so.
Or not! While investigating what it would take to enter Service mode, I came across a boating blog that referenced a forum in German with a handy reference pic. After a quick Google Translate on the annotation in an image from the forum for confirmation, I had my answer.
Turns out that if you ground the 2nd pin from the left on the top side of the diagnostic connector as oriented in the pic shown below, the MultiControl HD will reboot with Service menu enabled. Note that you need to keep the pin grounded while operating the Service menu. I simply used a multimeter probe with the other end grounded to the vehicle using an alligator clip.
And presto! The temp sensor value is now displayed in the status bar. Easy peasy. (And yes, I work on my van at weird hours.)
Old 02-26-2020, 12:52 PM   #2932
Found this channel on youtube the other day and it's opened my eyes on how and where to apply sound matting in a vehicle.
The channel also discusses the various types of sound matting and it's purpose.
Having bought and installed both ThermoTec and DynaMat (the foil backed mastic)...and recommend DynaMat. It's about $1/sf more expensive, but the material sticks easier and doesn't transfer the foil backing to your fingers or tools like the ThermoTec.
Also installed the Dynaliner and it really works.
I'm only partway thru with the sound matting on the van and I'm learning that this may be the most important item for a quiet van.
Chris
2006 E350 EB 4x4 SMB: 6.0L-5R110-Atlas-D60-D60FF-yada-yada-yada
Old 03-01-2020, 12:14 PM   #2933
simplesez's Avatar
Timing cover gasket on the 7.5 460. Today has crept into 3 days now [emoji2962]
Old 03-02-2020, 01:03 PM   #2934
Did the port install on my water tank. 6.5 inch hole saw off Amazon. Was some ikcy stuff in there. Not anymore...
Old 03-02-2020, 01:52 PM   #2935
gahamby's Avatar
Yep, recently did the same.
'07 GMC 2500 6.0
Old 03-02-2020, 02:46 PM   #2936
wanderers's Avatar
You're being too modest. Your post was what led me to install one and probably others, too.
wanderers is offline   Reply With Quote
Old 03-02-2020, 03:23 PM   #2937
Ordered and received the hole saw, then the part. Now can't find the hole saw.
wahoo is offline   Reply With Quote
Old 03-02-2020, 04:05 PM   #2938
wanderers's Avatar
If it's any comfort, you're not the only one that kind of thing happens to.
Old 03-02-2020, 04:15 PM   #2939
I'm getting used to it, tomorrow is my 73rd
Old 03-03-2020, 07:09 AM   #2940
wanderers's Avatar
My 73rd was 5 1/2 weeks ago. My bit of commiseration. I did wake up this morning, though. That's always a good sign.
