RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-11-2020, 10:25 AM   #3081
Fixed the penthouse J-hook rattles......so nice!!!!!!!
Popped grommets in the holes.....simple.
The holes are 1" diameter and the metal is 1/8" thick. With powder coat they are about .140" thick.
Amazingly, I could not find an exact fit grommet at McMaster Carr, but the grommets I bought for my rear bumper backup sensors worked well after I cut out a small pie shaped section to make them smaller.
2000 KTM 200 EXC
Old 10-11-2020, 04:35 PM   #3082
My contacts load thru the unit automatically, Bluetooth.
Futrmbl is offline   Reply With Quote
Old 10-11-2020, 10:51 PM   #3083
PRERUNNERCAMPERVANNER's Avatar
I Finally Just got a little bit of solar..
I really haven’t had a need for a very fancy high power system so I hope this will do. After having my van for over 3 years now I just hopped right into it. So I put a Renogy 160 watt panel on the roof and a flush mount Renogy 30 amp Adventurer charge controller. Now I’m on the hunt for a proper battery. I put an old battery out of my Jeep in it to test everything and It seems to be charging it up nicely. I’m a little excited to have some more juice in the future!
57FB3D39-8742-4FB5-9EBE-6798C4FC38B5.jpg   997A882E-D713-4250-94D1-9B3F49494054.jpg
Vanborghini
PRERUNNERCAMPERVANNER is offline   Reply With Quote
Old 10-12-2020, 07:50 AM   #3084
Twoxentrix's Avatar
Brilliant!
Old 10-25-2020, 02:42 PM   #3085
Twoxentrix's Avatar
No bent Pop-Top cross bars for me with this resolve: it almost became a reality yesterday when I began to raised my roof so I could clean & condition the canvas/glass... Hook behind drivers seat caught on the way up and I JUST HAPPEN TO SEE IT before any damage was done.
After reading over the years about how often this "accidently" occurs, I thought for sure it would never happen to me since I'd been forewarned by those examples.
Fixed the issue by installing "Marine canvas hooks" directly across from the Pop-Top hooks - too obvious now not to utilize them.
Small 1" black wood screws go right through the small hole they already have in the center, and it mounts easily to the roof. Also purchased the rubber grommets from Ace Hardware down the street (had the correct size for 90 cents each) and followed the advise of boywonder and applied them in the holes the hooks latch to.
Old 10-25-2020, 06:18 PM   #3086
Originally Posted by Twoxentrix View Post
No bent Pop-Top cross bars for me with this resolve:...Fixed the issue by installing "Marine canvas hooks" directly across from the Pop-Top hooks - too obvious now not to utilize them...
A simple, brilliant solution!
Old 11-21-2020, 03:39 PM   #3087
velo47's Avatar
Since I got back from my Wyoming pronghorn hunt, I put some lights on the van, and an antenna...
and a GMRS radio under the homebrew cup holder...
and finally installed the deck plate that's been sitting around for about a year in the water tank.
And on my truck, I installed a front half bumper and winch, and the gas tank skidplate that's been sitting around almost as long as the deck plate!
W3TAX
WRDZ686
2016 4wd 144" Sportsmobile Sprinter
2019 Chevy Colorado ZR2
2002 lifted & armored WRX wagon (sold)
velo47 is offline   Reply With Quote
Old 11-21-2020, 08:49 PM   #3088
Well, not just today, but being stuck at home for the summer resulted in all new suspension front and rear, (ball joints, tie rod ends, bushings, bearings,etc) new remote reservoir Fox shocks, new full float differential rebuilt with Yukon gears and a Duragrip, new brake rotors and calipers, LED headlights, a new parking brake set up, a trac bar,a new diesel heater, some tube work (unfinished though) carpet, lighting, gauges, wheels and tires, and more. Now it's time to go out and play............
Old 11-21-2020, 09:12 PM   #3089
geoffff's Avatar
penthouse J-hook rattles?
Glad you solved that problem, but I'm a bit curious why your J-hooks rattle in the first place...(?)
I keep mine screw-adjusted so tight that they never rattle. Am I doing it wrong?
-- Geoff
2004 Ford, SMB 4x4, RB-50
Old 11-21-2020, 09:24 PM   #3090
Bellpilot's Avatar
New Method wheels look great on the van!
2010 E350 6.0 4x4 EB 50 SMB
