05-09-2023, 11:17 AM
#3401
When MrAnderson parked his van in my driveway some time back, we blew the whole system through with compressed air which helped quite a bit… could be an easy “improvement”?
Here’s a pic of what I did:
Hoses right and left removed (circles), pushing it out of the clips marked with the red arrows and that’s it. No tools needed, beside a small screwdriver to remove the clip on the hose.
Based on my research the next I would have done would be swapping the sensor.
But for the rest I’d guess making sure all tubes/ hoses/ connectors are not plugged, not sure what else it could be.
Beside a failure code: I guess fueling should work when just disconnecting the whole unit at the tank, wouldn’t it? This way you could narrow down step by step where the problem is.
05-09-2023, 07:50 PM
#3402
Motovan....have you replaced your vapor canister? I have this issue but it's not too bad and somewhat intermittent. Once in a while it clicks off the pump.
I have indeed replaced my vapor canister. My symptoms are not exactly the same as what E-350 and most others usually describe. You can see my lengthy thread here.
In short, the tank fills OK, but once the auto-shutoff triggers on the gas nozzle, a significant amount of gas splashes out of the fill neck. Every once in a while, I'll experience the issue where the nozzle clicks off every 30 seconds while filling, but that has only happened a couple times.
Completely disconnecting the vapor canister from the gas tank (resulting in the gas tank venting straight to atmosphere) has resolved the issue for me.
Out of curiosity, where do most 4x4 conversions locate the vapor canister? On my UJOR, the canister is located in the stock spare tire area, so the vent hose running from the tank to the canister is quite long. Wondering if that is enough to create some pressure buildup, even if nothing is clogged.
05-09-2023, 07:55 PM
#3403
Attachment 47143
Whoops, didn't see this before posting my previous reply. That vapor canister sure looks different than mine! Ford must have changed it at some point.
I thought I went through and ensured all the lines are not clogged, but my plan is to eventually do that one more time and maybe more thoroughly. Will have to attempt to track this down via process of elimination... really just don't enjoy crawling around under the van on the dirt. Sure would be nice to have a lift
05-10-2023, 11:42 AM
#3404
microwave didn't make it
I trashed the microwave unit. Bouncing along some washboard road, big crash in the back - the microwave had committed suicide by jumping to the floor. Discovered that it was held in place by a thin piece of wood - nothing to physically hold in place, just under tension. 2014 build...seriously poor based on the kind of roads these beasts are built to travel on. Guess I just added a little more storage space to the van
Jon
05-14-2023, 10:19 PM
#3405
05-15-2023, 08:36 AM
#3406
PatO, those stainless fasteners certainly cleaned up the hinge attachments. I've got a Ruenell bumper, but think I'll do something similar to mine.
2001 Sportsmobile RB50 7.3
West Central Mountains, Idaho
06-13-2023, 09:47 PM
#3407
Replaced and repositioned my water pump. The old one died over the winter.
Also re wired part of my electrical system to simplify it.
Larrie
06-18-2023, 11:01 AM
#3408
Added LED strip light
Looking at some old emails, I realize I started thinking about doing this in January 2021. Sometimes these things take a while!
Anyway, yesterday I finally replaced the original interior light fixture that is above the barn doors on the inside of my van with an LED strip light. The old light was never very useful, so hopefully the new one will be a nice upgrade! Plus now we can have fun colors for any van disco parties.
YoTerryH
2001 Ford Econoline E250
GTRV camper conversion
06-18-2023, 11:14 AM
#3409
Rearched the rear springs and added one more leaf. All new leaf spring bushings front and rear, new propane tank, new brake calipers, pads, parking brake shoes, and rotors, in the rear, new rear axle seals, put summer tires and wheels on, changed the oil, Rainxed the windows and hit the road....
06-26-2023, 05:34 PM
#3410
Finally had to replace my Lifeline house battery. It lasted for about a decade so not terrible. Took me way longer than it should have, but it’s done and no major loss of blood.
