06-18-2012, 07:31 AM
#931
Re: What did you do to your SMB today?
Originally Posted by Gnarvan
The rubber grommets are for the storage holes located somewhere on the bumper close to the swing arm.
OK, cool. I had a feeling that's what they were for, but wasn't sure. I figured I had drilled enough holes in my van for a weekend.
06-21-2012, 04:20 PM
#932
Oil/filter change (7800 miles since last change).
Drain trans pan and replace oil/filter.
Change transfercase oil.
Grease 3 zerks.
The transmission and transfercase were easier than the engine oil change.
Oil - $115
Filter - $15
Trans fluid - $60
Trans filter - $22
Transfercase oil - $15
$227
Now, I need to do the 100K maintenance: Serpentine belt, rad and heater hoses, coolant.
06-21-2012, 04:35 PM
#933
Let us know how you plan to change the serpentine belt.
I wonder if the tool in this video would make it easier? Don't know if there's enough clearance on our vans.
[youtube:2q0pqy3u]
Callsign KK6GIY
06-21-2012, 04:44 PM
#934
Actually, since I'm changing coolant and radiator hoses, I thought I'd remove the radiator to do the belt. More access is more better!
06-28-2012, 12:28 PM
#935
Adjusted the Penthouse Lift link/springs, much easier to lift with the solar panels on top:
viewtopic.php?f=2&t=1223&p=82876#p82876
95 FJ80 ARB/Kaymar/Emu
2005 AMG CL65 691hp 875tq
06-30-2012, 06:44 PM
#936
Set # 3.5; @ 8 years - 7 days, 60K miles - 249 miles.
Interstate Mega-Tron Plus MTP-65 Automotive Battery 850 CCA
Here's why:
http://www.sportsmobileforum.com/vie...p=82786#p82786
06-30-2012, 07:00 PM
#937
Changed my rock-punctured BFG left rear tire and moved on to wait for Monday to get a new tire in Durango. Not as glamorous as some of the other mods here but we were a couple of hundred yards above a narrow 15% +/- grade where changing tire would have been less than pleasant. Also, it proves once again that all good things happen on Friday afternoon.
-Don-
Life and baseball both sometimes are not fair, but it is how you play the hops that counts. —Scott Miller, NYT Sports
07-07-2012, 11:47 AM
#938
Ordered a Truckfridge TF65 12V unit today.
Attached a travel bug in the rear window.
Put the "gift" under the travel bug above the spare tire on the door.
Disconnected the hard wired 30 amp shore power cable and removed the old electrical grommet through the body. In place of the grommet installed a Marinco 150BBI.RV and wired that into the van electrical system. Then installed a matching electrical receptacle on the old shore power cord. This allows me to store the cable in the door rather than under the seat.
Removed the dryer vent that the PO installed in the side of the van. Built a patch our of sheet metal to cover the hole and sealed it with butyl rubber and screws.
Larrie
07-07-2012, 12:10 PM
#939
This holiday week since we are not camping I:
Cut off part of my spare tire carrier.
Cleaned and painted the back third of the frame and under body.
Modified and installed a U Joint Off Road skid system.
Installed a 25 gallon fresh water tank and Shurflo pump on the skid plate.
And one of the best things I have ever done to the van, installed the amazing "Door Talon"
2008 Ford E-350 V-10 EB
Transformer Interior
2004 F-350 Dana 60
07-07-2012, 01:44 PM
#940
How much work was that in the end?
