Old 04-14-2022, 01:24 PM   #3271
[QUOTE=gcvt;309872]Got my new auxiliary condenser mounted up today.../QUOTE]
Just in time for summer....
Old 04-15-2022, 09:58 PM   #3272
gcvt's Avatar
I figure six years without A/C is long enough!
Today: new faucet, new microwave, and a redneck funnel-less water filling system.
Greg
New van: 2003 E250 EB10
Old 05-01-2022, 06:10 PM   #3273
Oogs's Avatar
Dropped my 8 year old AGM from under the van. I have a replacement Lifeline on order as well as a new circuit breaker for good measure since it's been in the elements all these years. I'm surprised there weren't any battery tie downs in use despite the holes drilled in the bracket. I know it's heavy but I'll be adding them for good measure with the new battery. While I'm under there I'm dealing w any surface rust. I took a serious look at lithium but 3x the cost is a hard pill to swallow. Maybe next time.Click image for larger version
Oogs is offline   Reply With Quote
Old 05-02-2022, 06:57 PM   #3274
Speaking of batteries. I install two new Duracell X2 Group 27 batteries in our van today. I also was able to get 8 years out of the last set, so not too bad I guess. The lower cost ones were all on back order (like everything now), but I needed them now so I popped for the more expensive ones. $855 for the pair. In our RB50 they are located in a box inside the van in the rear passenger corner. Took about 3 or 4 hours altogether by the time I unloaded everything, cleaned it up, bought the new ones, and reinstalled them. They are rated at 92AH each I think and weigh about 60 pounds each.
Old 05-10-2022, 11:18 PM   #3275
sbgrimm's Avatar
Replaced the original outside shower, you know, the one with the white plastic hose that kinks, leaks, and is a devil to pull out. The new one has a stainless steel hose that pulls in and out like butter!
Bardo
2005 RB-50 5.4L V8 E250 "Blanca"
sbgrimm is offline   Reply With Quote
Old 05-11-2022, 08:48 AM   #3276
1der's Avatar
Bardo, slick and timely! Please post a link as to where you found that SS replacement! Thxs!
Old 05-11-2022, 09:26 AM   #3277
sbgrimm's Avatar
Here ya go, 1der: https://www.amazon.com/dp/B09DRYV31M...roduct_details
Pretty easy upgrade, if you bolt in the hanger that comes with it and remove the original SMB hanger it just fits.
Bardo
Old 05-16-2022, 09:19 PM   #3278
gcvt's Avatar
Removed a couple of the old light fixtures, that I had upgraded to LED a few years ago, and installed Leisure Coachwork's dimmable LED fixtures.
14.0"x 5.5": https://leisurervparts.com/led-rv-le...th-white-trim/
20.0" x 6.5": https://leisurervparts.com/leisure-l...te-4000-4500k/
Greg
Old 05-19-2022, 09:31 PM   #3279
Old 05-21-2022, 07:25 AM   #3280
Sweet! Like it!
BigRed4x4
BigRed4x4
Vanna
gahamby
