Old 05-21-2022, 01:47 PM   #3281
marret's Avatar
Yeah, me too. Cool.
Chris
Old 05-21-2022, 09:42 PM   #3282
larrie's Avatar
Replaced the rubber seal on the edge of the penthouse.
Larrie
Old 05-22-2022, 09:54 AM   #3283
Steve C's Avatar
Not sure if my water system is different than other SMBs of the same era (2001), but I’ve had issues with being able to drain the under body water lines when camping in sub-freezing conditions. I always had a slow drip, which would freeze. Added an inline valve after the pump so I can now drain the outboard water line. Of course this means that water is unavailable until the outside drain is closed again.
2001 Sportsmobile RB50 7.3
West Central Mountains, Idaho
Steve C is offline   Reply With Quote
Old 05-22-2022, 03:11 PM   #3284
Bardo -
Can you still close the plastic door with the new handle/fixture? Looks larger than the original.
D.
Botchan is offline   Reply With Quote
Old 05-22-2022, 05:22 PM   #3285
Steve C's Avatar
Originally Posted by Botchan View Post
Bardo -
D.
The pictured valve doesn't replace the SMB one, it's in addition to prevent water from trickling past the Shurflow pump and out the rear underbody drain valve. A couple of years ago I froze & cracked the fresh water hookup fill valve when I thought I had drained the line. At least on my SMB version, there was no way to prevent water from entering the fill line when I had water in the tank (even with power turned off to the pump). The new valve is only about 3" long and doesn't impact the door. I'm sure there are better methods to accomplish this task, but I just needed a quick and accessible way to prevent freezing the line again.
Old 06-01-2022, 12:27 PM   #3286
vandiesel's Avatar
Trying to augment my solar with wind. Will this fit?
Old 06-01-2022, 12:33 PM   #3287
Bellpilot's Avatar
would like to see the finished product and your new turning radius before I would attempt the modification. Let us know how it goes!
2010 E350 6.0 4x4 EB 50 SMB
Old 06-01-2022, 01:31 PM   #3288
Would that mean you can only drive in circles?
Like this autonomous car trap?
Old 06-01-2022, 01:34 PM   #3289
BTW: added my basic rack for Ray’s awning next days ;-)
Will eventually be Raptor lined, but that’s the basic set up
Gutter clamps: Smittybilt HDS (the ones with the right angle, not the 45 degrees)
Old 06-01-2022, 01:34 PM   #3290
This time with pic
Rufus
LARufus
Turtle
rafeman
