Originally Posted by pjpvi
Has anyone ever installed roller bearings in the Aluminess swing away arms?
I have spent a lot of time thinking about and trying to research exactly this idea, but have never hit on the solution. Hopefully someone works on it and shares the results!
Phil
I have fabricated some bronze bearings for mine. I did this about 4 years ago and have not had a problem with them since. I never have to tighten or adjust anything. Only put a few drops of oil on then once or twice a year. And I only have the two hinge setup.
So here are some pics of my spare tire swing arm pivot mod. The section cut drawing gives the best explanation of what was done.
The main goal was to eliminate all friction from the aluminum. All movement is now between steel and bronze or bronze and bronze.
The drawing is for the upper pivot, the lower is the same only inverted.
The main components are the shoulder bolt, bronze flanged sleeve bearing, lubricated bronze sleeve bearings and the lubricated bronze thrust bearing.
The swing arm pivots were bored out to very tightly except the flanged sleeve bearing, they had to be pressed in. Next is the sleeve bearing that was cut to the appropriate length and bored out to the same inner diameter that the swing arm pivots were bored to. That was then pressed on to the remainder of the flanged sleeve bearing.
The swing arm bracket (the fixed points) were drilled out and tapped.
Assembly went like this. Shoulder bolt got a steel washer and a thrust bearing. That was then put into the swing arm. Then one more thrust bearing with the ID being smaller then the shoulder of the shoulder bolt. When tightened to the now threaded bracket the last thrust bearing becomes fixed to the bracket.
To do all this you will need a lathe and a drill press. All of these part were bought from McMaster Carr and then modified on a lathe and dimensions were very critical. A reamer was key to getting the swing arm bored out to the right ID.
Cheers,
John
