Re: Winterizing
I used antifreeze the first year, but after knowing the system, and drain points have,1. pulled the anode rod plug,1& 1/16 in, socket.
do this when the van is tilted to the left side so all h20 drains. Open all petcock valves in the lines, back under the storage cabinet near the floor and the one outside near the propane shut-off valve.
Next I pull the clear plastic top off the screen filter to the left of the pump, after placing a rag under it to catch water. Then loosen (break) the compression fitting (plastic) to the right of the pump, again catching residual water in a rag.
Then place the van in various steep angle positions right to left, front to back to allow the static water to free flow to the openings. drive around and let the motion remove more low point water. Any residual water may freeze but has no pressure against it to cause breakage.
This method worked lat winter to -10 f.
In the spring close all valves, reinstall the anode plug, clear filter cap, and (broken) open joint to the right of the water pump.
this is easy to do although sounds like a lot of steps.
07 E-350
