Originally Posted by 1der
The pad with the piston is wearing faster?
Yes, the inside pads.
"Proportioning valve. How much braking is your rears actually doing?"
I have no way to tell, but the issue in not a lack of braking, it's uneven wear of the pads.
"Bent mounting bolts / pins?? Been a while since I have dealt with my van brakes so do not remember all the pieces. Some components were not replaced right?"
I would think anything bent would be obvious as everything was assembled. In addition, it's the same issue on both sides and it's unlikely something would be bent the same on both sides. Pretty much everything has been replaced more than once. If your referring to something incorrectly installed, that would be difficult as the parts only go in one way.
"arctictraveller, does your van use the stock 2001 Ford van calipers?
When you install new components do the brakes drag at all?
What rotors are on your van F350?
What caliper mounts are on your van? F350?"
Since I'm working on the rear axle, as far as I know, everything is stock Ford. When I order calipers and pads, I get the correct ones the first time when specifying a 2001 Ford E250. As for the brakes dragging, I'm not sure I could tell, but I suppose they could be.
"Have you checked the PVC valve Just tripping on the V10 thread, sorry."
Not yet, but good idea, thanks..........
