Old 03-02-2022, 08:38 AM   #11
Unreng......thank you sir!
bonedoc is offline   Reply With Quote
Old 03-06-2022, 12:11 PM   #12
You should find an OE interrupt option for that harness. Sites like FordPartsGiant, TascaFordParts ….
Another alternative would be high current BlueSea Disconnect (red knob).
Last, Anderson PowerPole connectors.
1DogRescuer is offline   Reply With Quote
Old 03-06-2022, 06:13 PM   #13
Years ago I cut the frame rail battery cable and installed a heavy duty Ford style ignition relay. I mounted it to a ignition wire. When I turn ignition to run it energizes relay to give power and charge but isolates them when off. I was getting a parasitic draw on my frame battery, still don't know why but it cured the issue?
Old 03-07-2022, 01:49 PM   #14
porschedpm's Avatar
what about using a high amp connector plug like this:
https://www.amazon.com/dp/B08877PMQP...n_1_title&th=1
2006 E350 SMB RB50 6.0 PSD
porschedpm is offline   Reply With Quote
Beatrice
Drizzt
PigPen
velo47
