Old 07-17-2012, 07:10 PM   #1
GreyDawg's Avatar
4D AGM battery capacity / solar panel to match?
Hi --
Sorry, but this is a very naive question....
When SMB-TX did electrical work on my homebrew in 2009, they added a 4D AGM battery ($495) under the van step, as they do with the RB-50 layout.
Now that I'm thinking about adding solar, I need to know the capacity of the battery. I can't find it on my receipt, nor can I find it on the SMB website.
Can anyone help?
Also, once the capacity is established, how do I figure out the correct size of solar panel to match the battery?
Thanks,
GreyDawg
GreyDawg
GreyDawg is offline   Reply With Quote
Old 07-17-2012, 10:35 PM   #2
rockbender's Avatar
Re: 4D AGM battery capacity / solar panel to match?
You are probably in the 180 - 200 ah range, depending on the specific battery. Someone else with more knowledge than I will chime in, but I'll try to share some basics from what I've learned from other folks here.
First off, your solar panel should be sized based off of your demand or usage, not so much your battery size - especially since an AGM can take quite a current load while charging (while standard wet / deep cycle batteries in theory shouldn't take on much more than C/10... C being your Ah).
Tell us what your power consumption is as well as the maximum number of days that you want to stay out without starting the engine and we can get a better idea of how much solar you might need.
Josh
Old 07-18-2012, 09:27 PM   #3
Originally Posted by GreyDawg
Hi --
Can anyone help?
Thanks,
GreyDawg
Your battery should be 200-220 AH as stated. Most of the loads that are needed to be figured in are always light loads that regulate on off or those that run in a continuous mode. Never worry about heavy loads like the microwave and measure amperage off things like the refrigerator, fans, or things like the light loads required to run the propane/diesel heaters. It seems like there isn't too much use for large panel systems that produce over 15 amps as most of the items I mentioned don't pull over a few amps each. The idea is to hold enough battery reserve to supply the big use items for short periods of time and light continous loads that run throughout the night. A 130 watt panel does a pretty good job for a single 4-D. I have two 4-D's and two 135 watt panels on my van. I would not go smaller than 50 watts using a 4-D battery.
The other factor is overcast. Some might need more panels just to get a light charge in on/off sun or fog but spending the bucks for an extra panel to get an amp or two might not be worth it.
Good luck
Old 07-19-2012, 10:04 AM   #4
In reality, you don't need to match the solar panels to the batteries; you need to match your solar panels to your electrical load.
Old 07-19-2012, 10:29 AM   #5
My point is not matching the panels to the batteries affects the charge time. Too small of a panel setup can cause extended charge times with large battery banks especially during lower light conditions. If I use my microwave during the night and it pulls my two 4-D batteries down to say 60%, it will take much longer to recharge them than with a small panel setup. But I agree that there is a point where more might not be worth it.
