Originally Posted by Vanguy
Also upon closer inspection not sure there is room for 2 of those boxes. Forward space is limited by the track for the sliding door. Also tried installing the group 24 deep cycle battery I have and discovered the battery hits the floor of the van about 1" below where the bolt holes line up so thats a no-go as well.
I have barn doors on the side, not a sliding door. I mounted the front box slightly forward of the stock holes and spaced the rear box enough so I could get my hands in there. So there was some drilling involved but not too bad using a HF 90 deg angle drive and step drill. I probably had to drill three sets of extra holes but not sure at the moment. The front box has to go forward and the rear box has to do some finagling with the exhaust hanger.
These things get more use than you can imagine under a van LOL.
https://www.harborfreight.com/38-in-...ent-69337.html
From all my measurements the group 24 from O'Reilliy's will need 1/2" top clearance to account for the stainless wingnuts and studs. There is room as far as I have been able t measure without physically putting one in.
https://www.oreillyauto.com/detail/c...xoCsjEQAvD_BwE
