Originally Posted by Vanguy
Posplayr I found a battery box on ebay without the lid for $20 plus shipping or $50 with the lid. Tempted to cheap out but maybe the lid is necessary or at least desirable? I COULD make something but time is a valuable commodity as well. Just mounting up something that's already fabbed and matching sounds like the ticket for this job.
I bought the complete boxes that had the tops and all the frame mounting hardware and the battery hold down inside.
I was planning on using this battery, even though it might be a little tall. The top is non-metallic and can be spaced up for clearance if needed. it is close.
https://www.oreillyauto.com/detail/c...250-super-duty
I don't know how much current you plan on pulling but I would also put one of these down into the first box to protect both. If you go with the O'riely 80- amp-hr that is 160 Amp-hr and at C/10 you have 16 amps.
A 300W inverter I have pulls 29 amps so it all depends on your setup. The 50 amp breaker will sustain 60+ amps for quite some time but will open before a 70 amp inline fuse (this is an estimate based on some recent tests).
As a benchmark using the breaker in series with the fusable link a 600 Watt invertor limited the draw to 50 amps. A 30 amp auto-reset breaker opened in 60 seconds and the 40A fusible link blew in 30 seconds. Based on this I'm sizing my LiFePO4 100 ampHr batts to 70 amps using 50 amp breaks and 70 amp fusible links. That is plenty of current for most anything you would probably do even for the pair of deep cycle batts.
