RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 11-28-2020, 04:38 PM   #1
Ruthless's Avatar
Air compressor fuse
The extreme air compressor in our 2012 E350 SMB suddenly quit working. I found the circuit breaker and that was fine. I’m thinking it might be the fuse but can’t find it. Can anyone tell me where it might be?
Ruthless is offline   Reply With Quote
Old 11-28-2020, 05:15 PM   #2
Twoxentrix's Avatar
Could be a couple things, but my first suggestion would be to "jump" the compressor using its terminals. I had gone through several scenarios trying to get mine sorted out a while back and finally decided to see if it was the compressor itself. Turned out is was fine - issue was elsewhere.
Try this thread for info:
https://www.sportsmobileforum.com/fo...ing-26738.html
EDIT:
https://www.sportsmobileforum.com/fo...ure-24324.html
Old 11-29-2020, 04:10 PM   #3
Ruthless's Avatar
I found the fuse and that was the problem. The fuse was located under the hood on the driver's side of the van.
Tags
air compressor, fuse
Tatonka
gephoto
Tan Hot Dog
Jsweezy
