all lighter style outlets are dead
Recently on a 2 &1/2 week trip I realized a dash cigarette lighter outlet stopped working. A few days later I noticed the lighter outlets in the van house had also stopped working. Then the two lights on the inside passenger side stopped working. The only change this trip was I had my ebike with and was using the inverter to recharge the ebike battery most days. At home I went through the van (ford) fuses and changed one that looked funky. did the same on the house fuses and changed the one obviously bad one, the two inside lights worked again. Van is in the shop for possible fuel pump issue now, but need to figure out a direction after I get it back. First I'll recheck fuses, from there ....? if I can't sort this out should I take it to my mechanic or the rv repair guys?
Thanks
2004 F-350 Sportsmobile
6.0, Sptsmble 4x4
