Thought I would update this thread as a changes a component in the system. I wasn't real happy with Marinco 12VCP - ConnectPro Receptacle & Plug Kit. So when looking around I found this
on the powerwrex website. I have used anderson pole connectors for heavy amp connectors, but never really looked at their smaller amperage connectors.
As you can see you have two aux connection points, so I made up a pigtail to go from 1 10 gauge wire to two 10 gauge wires, so that both connectors would be live.
The butt joint connectors can be found a Waytek Wire
#32990 Sealed Multiple Wire Connector, One 12-10GA to Two 12-10GA
Now I have two aux solar connectors
On my Lensun cable all I changed was the Connect-Pro Plug.
I also had purchased a very cheap aux setup a while back, it is basically two flexible panels held together with a zipper. The quality of the unit lacks so I will not be posting a review on it. Anyway for it the parallel MC4 connectors at the panels were two much, So I used the same butt joint connectors above to combine the panels and put an Anderson pole connector on the end.
I then made up a cable with both ends being Anderson-pole connectors.
I made a couple cables 15 ft & 25 ft, as they can be used as extension cables
This is the flexible panels, they deploy a little easier than the Lensun, really don't take up a lot of room.
The hardest part about making the Anderson-pole cables is keeping the orientation correct, of course I also needed a new crimper.
