Originally Posted by Bear
Upgrade the folding solar panels to say a 200 watt or add another 120 watt panel?
The larger the panel configuration, the more you'll experience some awkwardness - setting up, finding a good spot to deploy, etc.
I have two EcoPower 120 watt panels that set at the end of a long cord - both connect to the end of this single cord using an MC4 "Y" connector. Essentially I can position both at a slightly different angle to capture sunlight through more of the day vs having to tend one large unit throughout the afternoon.
A smaller suitcase panel also allows for more creative options in placement (hanging from trees, rocks on the river, and the list goes on). Plus, there are just as many instances I find I only need to setup with one suitcase vs both.
So I'd suggest adding another 120 watt suitcase to your arsenal.
