Originally Posted by E350
JWA: I knew if I posted on this forum long enough, someone would call me "crazy." But I didn't think it would be you or over batteries... BTW yvrr my experience is the same as yours with Duracell, they have been leaking in some pretty expensive devices. Helmet cams, etc.
So a related question, any suggestion on how to clean that white/gray corrosion off the battery contacts in a device?
Didn't mean to imply or call anyone crazy especially not you E350
My only thought was is this that big an issue for most of us? Indeed we all might have different priorities when it comes to what are disposable batteries.
Duracel certainly is a brand name that carries a premium price, perhaps only due the name. The ProCel versions in my experience have always performed beyond expectations and their somewhat unique characteristics make them great for a longer useful life in devices that need a constant voltage/amperage output.
Leaks even after a few years haven't yet been noticed but I'd never claim its impossible. Most times leaking cases have been discovered it was always a "lesser" brand---pick one.
When/if they do leak the small brass bristle brushes are great----gun cleaning tools would work for this. For electronic remotes or similar devices most electronics supply houses have different chemicals for this very use. Careful selection is important as some can damage battery compartments--for this reason I tend to stay with the mechanical process of corrosion removal.
