Originally Posted by Chams
Thanks posplayr
I actually was already aware of each of your bullet points. I think I like the idea of a solenoid but had decided it didn't work for my setup because I'll be using a propane heater as well. I plan on chasing mild weather but if I'm using the heater for any extended period I wouldn't want the solenoid on for the whole time eating up my juice. I was going to just have a manual valve in stead.
I was just a little concerned that there was an attempt to minimize the risk of spark from electronics; there is an explosive consequence even if the probability is low. Risk is the product of probability and impact.
So your comment about solenoids prompted me to go out and measure the current draw with my trusty new DC current clamp. It is pretty high quality and measures sub amp DC current.
https://www.ebay.com/itm/333681392226
I've got one of these but I try to be more careful with it.
https://www.newark.com/tektronix/a62...-dc/dp/01F2474
So at 12V across the coil of the solenoid it warms up and would be greatly helped by something flowing through to keep it cool. There was just at 1 A at 13.5V which I figure is LiFePO4 resting voltage.
I then dropped it down to 5V and the current read was 450 mA(as measured by the new clamp).
5/13.5*1=.37A so the clamp is reading a little high on the low scale.
I'll have to see if I can use a little DC-DC chopper to apply 5V for the solenoid control. These are cute and you can stick almost anywhere. Half the current is quarter the power.
https://www.ebay.com/itm/123798965111
