Battery charger not working
I have a progressive dynamics pd9100 battery charger that recently stopped working. During hurricane Ida we were going to use the onboard generator and sleep in the van. Generator was shutting down after 20-30 minutes with load on it. Then it was shutting down as soon as I flipped on the breakers. Since then the charger has not been working.
I just checked the battery reverse fuses on the charger and they are both good. 110 power receptacle that it is plugged into is working. Any other ideas of things to check?
It’s a 2005 model that is original equipment. Could charger need to be replaced? I also have some solar panels on the roof, how is it wired into the system?
