Again,
The separator appears to be working, upon starting engine alternator fires up, voltage on Start Battery side of the Separator goes above 13.2 volts and the separator connects the house and start batteries. At this time you appear to have power on the house side of things and all is working well.
Now, when you turn the engine off, the voltage starts to decay and drops below 12.8 (that is your time delay between before you hear the click). Now the two battery systems are disconnected or separated from each other.
The Separator is not between your house battery and shore power charger.
You should be able to read the voltage on house battery in this mode.
So I would start checking stuff on the house battery side.
