Originally Posted by Scalf77
I don't understand the comment about all the 8awg wires should be 40 amp.
As long as the fuse protects the wire size, it would be ok to have different sizes. a 60 amp fuse would still protect 8awg wire( Based on 105C rated marine wire)
So I have been reading the thread and trying to resolve in my mind what are the general "rules" that should be followed as far as fusing. The layman's "rule" that
"The fuse is to protect the wire" is misleading, at least that is what I have come to realize.
Despite this rule, we still size the fuses to the expected maximum current of the devices in normal operation, not to the size of the wire. The wire may be sized to the current loads, but as in the example circuit, wire capacity can well exceed the normal max current loads.
Rule #1 Battery Connections:
So to try and narrow this down a little more, I would like to first, discuss an an overarching rule when dealing with batteries.
"Any positive battery connection should be fused nearest the battery whether it is a load or a source." If it is a source (with any appreciable conductor length) then it should be fused at both ends.
The main reason for this type of precaution is the danger of shortening a battery whether Lead Acid and/or especially Lithium batteries.
The reason to fuse loads is that the distribution (branch) wires (in the example case 8awg wires) would not be protected by a 150 amp main busbar breaker if the wire or device became shorted.
Rule #2 Fuses are intended to Protect Wires.
The confusion is that this means to have a fuse in place closest to a source but doesn't speak to the fusing of the wire other than it needs to be below the rated current of the wire.
To add even more confusion, I would argue that strictly speaking there is little difference between Rule #1 for battery connections and Rule #2 for protecting wires with Rule #2 being the overarching albeit vague rule with Rule #1 only applying to batteries.
For myself, I like to have Rule #1 so that when I look at the battery connections I make sure there is always something (a fuse) to protect anything that is downstream of a positive battery connection.
Rule #3
"Fuse values should be selected to minimize the excess between the maximum current fusing limit and the expected maximum conductor currents".
The reason for this is that while the fuse is to protect the wire, the wire can be protected at anything below its current rating including much lower if the real loads can still be accommodated.
The rule then provides a more reliable warning about an electrical short in that the fuse will blow at the lowest level avoiding high shorting currents albeit within the wires rated currents. It is assumed that a blown fuse will be a clear indication to the user that something is wrong.
Rule #3 seems to be the one that is contradicted by Rule #2, but Rule #2 only relates to where a fuse goes not its value.
I don't know if this adds any clarity to the situation, but it has helped me go through the issues in my own mind.
