Old 01-21-2016, 01:40 PM   #11
shenrie's Avatar
thanks carringb, great info! ill have to give that a try since i already spent the jing on them fancy bulbs to begin with
Originally Posted by arctictraveller View Post
Can't you install tow mirrors with built in blinker lights? Or is that just the F series?
ive seen auctions for them on ebay specifically designed for e-series. cant recall seeing an oem option though...
For Ford Super Duty Pickup 03 07 Power Heated w Signal Towing Mirror Pair | eBay
Old 01-21-2016, 02:21 PM   #12
Karsten's Avatar
I use switchback LED's from SuperbrightLEDs.com front and rear. In the front I use white as DRL & parking lights (no amber parking lights allowed here) and amber for the turn signal. If you switch on the turn signal the white LED shuts off and the amber part flashes. After turning off the turn signals the white will go on again.
In the rear I use the switchbacks for backup/turn (no red turn signal allowed here), but those are a bit different. If you put the van in reverse and hit the turn signal the white and amber lights up alternating. Those are a bit dimmer than the ones in the front, but overall brighter than the stock bulbs.
The flasher is just some generic heavy duty electronic one. Housings are the stock clear ones.
The rears:
The fronts in my old RAM:
'98 E-250 5.4 2WD Cargo Van
Karsten is offline   Reply With Quote
