Re: Charging Camera Batteries
The short answer is your inverter will only draw as much power as it requires for a given load plus a little overhead. Inverters are typically 85%-95% efficient.
The reason why you should turn off an inverter between uses is because they draw power even when there is no load. This is known as "idle draw". Some pull more than others, check your manufacturer specifications. For example my Xantrex ProWatt 600 pulls ~800mA at idle or .8 amps at idle.
Callsign KK6GIY
