If anybody decides to go this way using the basically high capacity naked (thin aluminum shell) cells, you have to realize that their packaging of these cells is pretty critical as ignorance of this in a mobile application can result in cell shorting and fire.
If you are only looking for 100-200 amp hr of capacity, then I would probably suggest just buying from one of these options.
https://www.mobile-solarpower.com/li...batteries.html
If you want to be more adventurous then go for these reinforced cells that are going to be easier to package. Realise that in a price comparison total to the door all in (with shipping)price for the 280 amp-Hr grade A matched cells is $147/280 ampHr (290 actual) while these Fortune 100 amp hr cells are 126 + tax and shipping conus.
So they are approaching 2.5x to 3X more expensive.
https://www.electriccarpartscompany....ncased-Battery
If you go with the EVE cells then be prepared for doing some research and design work. A 32 cell 48V battery is going to be a lot of energy and you want to make sure you have some protection in the event of a fire. It is rare, but it can happen and it best not to have to say "..Whoops burned the house down"
As I start to build my enclosure for the 200 Amp-hr van battery I will document the process or at least the design.
