Re: Do 12V DC plugs work on van battery or house battery?
"The only thing I could suggest is look for a GFCI tripped switch on one of the outlets. If that has tripped everything wired from that outlet will not have power."
The GFCI outlet isn't tripped and seems to be working fine. Everything plugged into it works fine. I just have no clue what the DC outlet is wired to? I guess I should just contact Sportsmobile...I'll post some pics of my setup which sounds like the same set up as what has been mentioned. I'm wondering if this outlet was meant for the CB radio? I tested the wires that run to the dc outlet and there is no power to them so I need to figure out where these wires go. Thanks again for the help.
Always looking...4x4 Van 19ft or shorter. Sleeps 4 - two together, two separately; 4 forward facing seats with shoulder seatbelts, interior shower, water heater, 110 power, sink, aux. heat, aux air conditioner, aux. battery, generator - all at a price a school teacher could afford...help me Obi-Wan Kenobi you're my only hope.
