[QUOTE=JWA;280744]Those should be readily available from the dealer (of course
) or online. They are electrically the same as the front door switches but mount very differently and naturally the wiring harness connectors are different as well.
Look for Ford part numbers(s): F8UZ-14524-AAA for just the switch & bezel combination, if the connector is needed its: 3U2Z-14S411-TXA or Motorcraft WPT-527 but it won't be any less expensive than the Ford part. Chances are good you will
not need the connector.
Thank you! I will try to look for those.
