Originally Posted by doublevan2
My main ceiling light is out (12 volt) and per Scalf77 suggestion I pulled back the gray fabric at driver corner of PH top - by removing the narrow wood panel running above cab seats - found what looks like regular house lamp cord - with a "10 amp" inline fuse - not 7.5 amp fuse. I replaced fuse - but still no ceiling light. Have not checked fuse panel under bed yet.
My water pump is still working (unlike mentioned in previous post above). I'll check fuse box for the 30 amp in the morning - its 95 degrees right now.
Also - I thought my StarCool AC compressor was failing and tripping the main shore power breaker in my storage unit - but after my wife watched the thermometer on StarCool vents as I drove around - reading 60 degrees - so all good there ! - could what's shorting the ceiling light (?) also trip the main breaker for shore power - being only 12 volts ?
A couple of things here. Since your fuse was not blown one would doubt it is shorted out, is it both ceiling lights? At some time you need to make some measurements with a meter. Find a good ground that works for measuring 12 volts, you could then measure at the fuse holder before it goes to the ceiling. If there is voltage there you need to measure at switch on the light. If you are still seeing power there, then you may want to check the ground at the light. Just move from the common ground you are using to a ground at the light. Most of the sportsmobile grounds get screwed to the body. If they loosen up the circuit will become open and never make it back to the battery.
On the starcool, when driving you are not using the 120 volt compressor, so it working while driving doesn't mean the compressor doesn't have issues. It would be very hard to tie the ceiling light and starcool breaker going off.
