Old 10-25-2020, 05:12 PM   #1
Electrical system from scratch
I am pretty electrically inept and i k ow there are electrical experts out there.
I am going to have a house battery that is connected to the alternator to charge while driving. But how do i connect this house battery to shore power when stopped? Can i just connect a regular battery charger to it with it plugged into the 20 amp shore power? Does this work also if i using power out of the battery at the same time? Or options to have a inverter and 12v connector pulling power of low watts.
Hope this makes sense what i am asking.
Thanks
Andrew
andrewpm is offline   Reply With Quote
Old 10-25-2020, 06:20 PM   #2
Connect the house battery to the battery under the hood and use a battery separator. First choice would be a blue sea 7610 or 7622 for more features at a higher price point. Surepower also make separators that work well.
There are a couple of common ways to do this that come to mind...
A transfer switch is a common way to do this.......these are built into Inverter/charger combo units; if you are planning on installing an inverter and want shore power consider an inverter/charger.
..or for a little less $$ you can install a charger/converter....Intellipower is a popular brand, if you go this way you want the optional charge wizard gismo that turns the dumb charger into a smart charger (I find the whole thing dumb.....they should just have the smart charging circuitry built into the charger/converters.)
See above..you can, but that's a bit ghetto and those chargers are usually dumb. A smart charger/converter provides much better care and feeding for your house battery.
Sure
Well..everything made sense up until your last question.....not sure what you are asking...
boywonder is online now   Reply With Quote
Old 10-26-2020, 06:40 AM   #3
You can get "AC/DC power centers" at a reasonable cost compared to a stand-alone converter/charger that integrates a smart converter/charger with an AC breaker panel and a fused DC distribution panel. It's definitely less expensive and much easier to install compared to a stand-alone converter/charger plus stand-alone AC and DC panels. Here's an example from PowerMax:
https://www.invertersupply.com/index...IaAsXvEALw_wcB
I'm currently in the process of installing one in my self-build.
Bob
2002 Itasca 35U Motorhome
BCam is offline   Reply With Quote
Old 10-26-2020, 07:20 AM   #4
Bcam: Inverter supply looks like they supply lots of useful stuff....excellent link...
VanBo
Mike Ponce
AWOL
Twoxentrix
